replacing a starter
LEVEL UP
replacing a starter
Well, my starter is on its way out. Can I just get a decent replacement from somewhere like Autozone? I thought I remembered reading somewhere that there starters don't bolt up exactly right? Anyways, I'd be changing out the starter in a '94 GSR. What steps do I have to take? Is it very hard? Thanks.
WHAT OK YEAH!
starter is very easy to replace it's just 2 12 or 14mm bolts. Make sure you disconnect the battery before you take it off. A starter from Autozone should work just fine Good Luck
How do my taillights look
yup, i got mine from pepboys. eveything fit well. all you gotta do is take out the intake. if you have A/C which im sure you do getting your hands around the lines is tuff. i think it took me 1.5hrs total. and i wasnt rushing and reading my manual. gl
LEVEL UP
Thanks for all the info! Any idea how long a starter that's "on it's way out" will last me until i can get the new one? (kind of an arbitrary question, i know....just curious.)
LEVEL UP
Originally Posted by honura
if they tell you they don't have the starter then order one off an ls, or 00 si. there the samething. fitment and ll.
Originally Posted by red94teg
Not to discredit what you're saying, but can anyone else verify that this is true? Thanks. I just called Autozone and they want $135 for a starter for a gsr...
