Abs Light
Old Nov 2, 2005 | 11:30 AM
st3v3nz's Avatar
st3v3nz
Default Abs Light
My 95 acura integra LS has an ABS light on??
could someone help me to clear this code?? and what might be the problem??
thanks guys.. appreciate it
Old Nov 2, 2005 | 02:16 PM
thumper's Avatar
thumper
My ABS light came on Mondy night. I noticed it about 10 miles from my destination and hasn't came back on since.
Shouldn't you find out why it's on before you just clear it off?
I think you can just disconnect the negative cable from your batter for about 20min to clear it.
Old Nov 2, 2005 | 03:12 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
if you really wanna just clear it off reach under the steering column w/ the car in accessory there is a little blue button...press and hold it....all the dash lights will flash once then shut off....turn the key to off then start it as normal....if it comes back on then u should REALLY get it checked out...but thats what ya gotta do it's just a way to clear the codes out of the computer...or u can go to ur local acura dealer and pay them $80 to do just that
Old Nov 2, 2005 | 05:02 PM
desauter's Avatar
desauter
Lonewolf
Look in the FAQ section of the forum and see how to decipher what your car is trying to tell you with that light.
Old Nov 2, 2005 | 09:07 PM
st3v3nz's Avatar
st3v3nz
I pressed the little blue button but it only cleared the maintenance req light on not the abs light... maybe i should try to disconnect the battery...
Old Nov 2, 2005 | 09:54 PM
rugsr's Avatar
rugsr
How do my taillights look
nope wont work, i tried. ive been meaning to get it looked at. i know theres a chart in the FAQ forum, that shows why its on. if heard it could be one of the wheels. you can also jack the car up and spin each wheel by it self and see if it goes on
Old Nov 2, 2005 | 10:20 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
The ABS light is on for a reason, meaning its getting something bad from a senser. I wouldn't mess around trying to turn it off, I dont think you really can until it gets fixed. I had lots of problems with my ABS last year. When that light goes on, you have no ABS. Luckily I found that out by testing it on a small patch of ice with nobody around. Try pulling the codes and find out whats going on.
Old Nov 3, 2005 | 12:59 AM
TribAI's Avatar
TribAI
Wannabe Gearhead
To clear the code you can pull the ABS fuse under the hood instead of disconnecting the battery (won't lose radio presets and such). I recently had my ABS light come on too. Tried to check the code and it gave me nothing, but it did stop the light from coming back on.
Old Nov 3, 2005 | 10:41 AM
st3v3nz's Avatar
st3v3nz
I disconnected the battery .. and now I have to put the radio code.. does anybody know where to get the code??? please help.. thanks guys
Old Nov 3, 2005 | 10:49 AM
thumper's Avatar
thumper
look under the ashtrey or under the fuse box lid under hood. thats where mine is
