Fuel pump install
Old Oct 28, 2005 | 08:18 AM
rugsr's Avatar
rugsr
How do my taillights look
Default Fuel pump install
Well, all parts are bought for the turbo setup, ok mabye like 1 more to go. BUT the fuel pump came in and id like to install it now. the weather is decent and i want to do it out side and not in my garage(fumes, high, spark, boom). anyways. can I do the fuel pump install now and still drive around for like 2 more weeks b4 i put the car away. Its the walbro 255LPH pump. so everything will be the same, BUT the new pump. i know where and how to do it. BUT will this hurt the motor in any way? Thanks guys
Old Oct 28, 2005 | 08:45 AM
seateg's Avatar
seateg
In a word: No.
You'll just have more fuel pressure when you floor the pedal.
Old Oct 28, 2005 | 09:12 AM
dubcac's Avatar
dubcac
I
He won't have more pressure. The pressure is still controlled by the fuel pressure regulator...he'll be flowing more volume.
Old Oct 28, 2005 | 10:12 AM
rugsr's Avatar
rugsr
so ill be wastin gas? worse MPG? what about motor damage?
Old Oct 28, 2005 | 10:33 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
No. As long as your fuel pressure regulator is in good working order, you won't notice any difference. The extra fuel will just be returned through the fuel pressure regulator.
Old Oct 28, 2005 | 01:07 PM
rugsr's Avatar
rugsr
ah so all systems go then. its still the stock reguator right now. ill put the new one in very soon
Old Oct 28, 2005 | 02:29 PM
Provocateur
On permanent hiatus
The stock FPR should be plenty sufficient for your future setup.
You really don't need an adjustable one unless your injectors are too small and to compensate, you increase the fuel pressure.
Old Oct 28, 2005 | 05:20 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
i'd get a fuel pressure gauge. my friend just went turbo but before he put the turbo on he put his walbro 255 on and left his stock fpr and when he installed the guage it was reading that his fuel pressure was at 55psi instead of 40psi.
Old Oct 28, 2005 | 07:46 PM
dubcac's Avatar
dubcac
I
Then his FPR wasn't functioning properly.
Old Oct 28, 2005 | 07:56 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
well its all done and fixed now so i guess it really doesn't matter...but hey i think the 30$ is worth the guage so you can make sure everything is good
