95 integra reving/slipping
Old Oct 23, 2005 | 08:07 PM
frank32's Avatar
frank32
Default 95 integra reving/slipping
hello,
THe car has 186k with a 5 spd man. Upon acceleration it seems the slip in each gear unitl desired speed is reached. This is a occasional issue, so anyone else have this problem? What are the future consequences?
Old Oct 23, 2005 | 08:14 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
Sounds like your clutch is slipping to me. Are you launching when this happens?
Old Oct 23, 2005 | 08:40 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
your clutch is slipping. sounds like you need a new one ASAP.
Old Oct 24, 2005 | 04:27 AM
frank32's Avatar
frank32
the car doesnt launch on take off...very intermittent...thought it might be the cltch...new one or just have it tweaked?
Old Oct 24, 2005 | 06:06 AM
teg92's Avatar
teg92
WHAT OK YEAH!
just get a new one OEM ones dont go for that much
Old Oct 24, 2005 | 06:44 AM
Exadar's Avatar
Exadar
Be Quiet and Drive
Its intermittent for now, but I promise you, it'll get a lot worse soon. If I were you, I'd just go ahead and replace it, you can't really "tweak" a clutch like that.
Old Oct 25, 2005 | 01:00 PM
Philip_Freda's Avatar
Philip_Freda
I want an NSX
replace the clutch, you don't want to have to have the flywheel machined....it will be intermittent for a while and then it will get worse.
Old Feb 14, 2006 | 07:30 AM
travis in wa's Avatar
travis in wa
Is that what'll happen if I keep running my clutch? It slips like crazy and has been for a long time.
Old Feb 14, 2006 | 09:45 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
well u can machine ur flywheel... but im assuming ur clutch hasn't been replaced in a while... it's HIGHLY suggested to get a new clutch before u end up getting fucked over with no clutch on the freeway. if the clutch is having trouble disengaging, soon enough it won't engage/disengage at all... and then u couldn't even drive it to the shop to get ur clutch in
Old Feb 14, 2006 | 10:09 AM
travis in wa
I'm waiting until it gets so bad that I can't drive up the hill to my house in 4th gear. Or go faster than 55 on the freeway. It's quite bad right now.
Will this damage the fly wheel and exponentially cause me grief if I keep letting it go?
