250whp (+-) B18b
Old Oct 30, 2005 | 05:52 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by a_integra_87
Sorry to bother ya Däs Schmoo, but i have a few q's if you wouldnt mind answering about turbo's and if needed building my ls block. I tried to PM you numerous times but your box is full. Do you have a email address or anything i can get ahold of you with?
Cleaned out the box. I didn't even realize it was full.
No wonder I haven't gotten a PM in over three weeks. h:
Old Jan 17, 2006 | 12:20 PM
LSturbo's Avatar
LSturbo
250 seems about right, i have a b18b with a t3/t4 turbo, 725cc injecters, Inlinepro cam gears,.. runnin 12psi with hondata... I dyno'd at 240whp and 211wtq... (W/Converter)
https://www.honda-acura.net/forums/s...d.php?t=197580
Old Jan 17, 2006 | 01:09 PM
97teg's Avatar
97teg
here are a lot of turbo ls setups:
http://www.honda-tech.com/zerothread?id=1323059
Old Jan 17, 2006 | 03:07 PM
rugsr's Avatar
rugsr
How do my taillights look
GSR only handle 250WHP, i was hoping 300 on stock internals. Heard this was ok.....What can a Type R handle?
Old Jan 17, 2006 | 04:55 PM
a_integra_87's Avatar
a_integra_87
Traction, WTF is that?
To tell you the truth I have seen a 300whp b18b on stock internals.
Finally got the b18b in the civic, working out some bugs. Im going to see how i like this setup and hopefully have it boosted within 3-4 months. Later on either build the b18b, ls/vtec or gsr built on boost at 300whp daily driver.
Old Jan 17, 2006 | 05:25 PM
sherwood's Avatar
sherwood
I missed Sean
5 lug is running 290 last i heard on a type-r
for anything over 250 it's a better idea to just rebuild an engine, and it has a good chance it might even last longer than if it were stock.
and people are too worried about such things as pistons at 300hp, i'd be more worried about my axles and other drivetrain.
to the original poster:
go www.hmotorsonline.com
their customer service is shit, but the product is 100%
Old Jan 17, 2006 | 05:35 PM
sherwood's Avatar
sherwood
I missed Sean
:dp:
Old Jan 18, 2006 | 11:31 PM
rugsr's Avatar
rugsr
i believe that 290 is at 7psi too. though the type R has 20more HP it has higher compression. so with a lower compression motor....GSR, you can go to 8-10psi and........mabye get to 300+?
Old Jan 19, 2006 | 03:47 PM
sherwood's Avatar
sherwood
I missed Sean
again, you'll be breaking more than the motor above 250
Old Jan 19, 2006 | 05:00 PM
a_integra_87
I dont believe you can just go by PSI to say what you will put out, a smaller turbo which will provide quicker spool with need higher PSI to make the power , and a bigger turbo which would spool slower would require less boost to make the same power. As well as the tuning and other systems. You could have 2 of the same cars with the same turbo setup and different tuning and fuel systmes and one would make more HP than the other.
(someone correct me if im wrong)
Right now im hoping for a 250whp daily driver, but of course with a boost controller I wont be running what ever psi for 250hp all the time, only at the track probably.
