chech engine code p1607
Old Oct 15, 2005 | 01:27 PM
gsrtommy's Avatar
gsrtommy
Default chech engine code p1607
i got a 98 gsr and the check engine light went on, so plug it into the computer and the code was p 1607 whick is emg/pmg internal circiut failer A. what does that mean? what do i fix ?and whats this gonna cost me?
Old Oct 15, 2005 | 03:02 PM
VPUPPY's Avatar
VPUPPY
it means that your ECM is malfunctioning(an internal problem). reset the unit by removing the under hood fuse. i don't remember the exact name for it but its rated at 7.5 amps. you can also pull the battery for a couple minutes. keep in mind, if you do either of these your radio will be reset and if you have the original one, it will require a code to be inputted.
after resetting it, start the car and let it idle for 5-10 seconds. if the code gets stored again(check engine light comes on), swap the ECM with a known good ECM. if that ECM does not store a code, replace your original ECM.
Old Oct 16, 2005 | 11:06 AM
killuminati's Avatar
killuminati
All through your body
It's called the back up (radio)7.5 fuse. Do exactly as stated above. You might want to look for someone selling a used P72 ECM.
Old Oct 16, 2005 | 05:41 PM
gsrtommy's Avatar
gsrtommy
i did what u said and reset the computer and light never went back on and it runs fine now.strange!
Old Oct 16, 2005 | 05:42 PM
VPUPPY's Avatar
VPUPPY
cool, it may have been a random problem. keep an eye out and if it happens again, something is definetly wrong.
