Blinking oil light
Old Oct 10, 2005 | 02:28 PM
pierced1's Avatar
pierced1
Default Blinking oil light
OK so this morning the oil light comes on, then this afternoon it starts blinking. I know theres been threads about this, i searched. But found no deffinant answer on what the problem is. It has plenty of oil, no leaks, nothing like that. The only other suggestion that i saw was the oil pump, which is timing belt driven if im not mistaken. I just had a timing belt and a water pump put on it, wish i would have thought to go ahead and replace that while i was at it. Could it be anymore possable causes. And how much does the average shop charge to replace the oil pump, any help is greatful. Thanks
Old Oct 10, 2005 | 02:39 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
It could be the sending unit or whatever it is that measures the level of oil.
Old Oct 10, 2005 | 03:02 PM
pierced1's Avatar
pierced1
would you happen to know how i could check that?
Old Oct 10, 2005 | 03:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It is at the back of the block above the oil filter. Check to make sure it is plugged into the harness and try a known good one.
Old Oct 10, 2005 | 04:46 PM
pierced1's Avatar
pierced1
i had a friend person who owns a shop tell me that it was the oil sending unit? its goin in the shop tomorrow to verify that.
Old Oct 11, 2005 | 08:49 AM
b16teggy's Avatar
b16teggy
I had the same problem outta my 94 ls. Replaced the sending unit and all was fine.
Old Oct 11, 2005 | 11:29 AM
pierced1's Avatar
pierced1
alright all thanks for the help, ill find out if that was the prob this afternoon
Old Oct 11, 2005 | 04:33 PM
pierced1's Avatar
pierced1
well just to let you guys know, it has a new sending unit on it and the light still blinks and it has plenty of oil pressure which would rule out the oil pump right? its still in the shop though.....
Old Oct 11, 2005 | 04:43 PM
b16teggy's Avatar
b16teggy
Did they test the oil pressure with a gauge? Thats weird. Was it a oem sending unit? If ithas good oil pressure Id say not to worry about it.
Old Oct 11, 2005 | 04:52 PM
pierced1's Avatar
pierced1
yea they told me i could drive it, but yea they tested it with a guage
