will this help me any?
Old Oct 5, 2005 | 07:51 PM
93LSVTECTEG's Avatar
93LSVTECTEG
Default will this help me any?
im running an ls/vtec setup in my teg,its b18a1 bottom end and the sir head,i have gsr cams and i am planning on putting them in it,will these help me any?i do not want to buy aftermarket cams,just playing around wit my teg,just trying to get a little more out of it,i have a chipped ecu and high flow fuel rail and bigger injectors already,will the gsr cams help me out any?would like some of your inputs and thoughts
Old Oct 5, 2005 | 07:54 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
Try posting it in the Hybrid Forum.... you'll have better luck, and i know TheOtherDave is gonna move it there as soon as he see's this post anyways.
oh welcome to HAN btw :cheers:
Old Oct 5, 2005 | 08:13 PM
93LSVTECTEG
o sorry didnt realize that my bad thanx for the welcome
tgansert's Avatar
tgansert
is all good
You should mill your head. 10.205 and all that extra fuel too.. I would mill the head at least .030 and get aftermarket cams.
Edit:
Sorry, your compression is even worse.. My calculations were originally a little off: 9.759
Old Oct 5, 2005 | 08:27 PM
dubcac's Avatar
dubcac
I
Milling the head is a waste. Bigger injectors are also a waste right now. The GSR cams will make a little more power, but go back to stock injectors...you don't even have a built motor. If you were running 12:1 compression and big cams to like 10k rpm, I'd say get some bigger injectors. Be careful about spinning that stock LS block to 8k...the rod bolts probably won't last long.
