transmission problems
Old Oct 3, 2005 | 08:23 PM
97 integra's Avatar
97 integra
Default transmission problems
I have a 97 integra ls and it has 85000 miles on it. Over the last week the car has become hard to shift gears when on the throttle hard, even under little throttle the shifting is real hard, but worse when accelerating fast. I talk to my local dealer and they said the syncronizers in tranny is going bad. I wouldn't think all would go bad at once and this early in mileage. Anyone with similar problems or has seen this with any advise please help. Also just in case where can i find a used jdm with lsd?
Old Oct 3, 2005 | 08:52 PM
tgansert's Avatar
tgansert
is all good
You should be able to get one here.
Old Oct 3, 2005 | 10:50 PM
BooSted_DB2's Avatar
BooSted_DB2
with the car off put it into gear if it is easy then you need to replace your clutch.If its still hard to shift when the car is off then check your shiftlinkage it may have bent and is binding up.I really dont think your syncros are going bad because it would grind.Maybe look into flushing your clutchmaster cylinder and put new fluid in
Old Oct 4, 2005 | 05:48 AM
Arrogant_'s Avatar
Arrogant_
Might be your clutch system. Happened to mine, and I found out that it wasn't my syncronizer.
You should have it checked out!
Old Oct 4, 2005 | 09:30 AM
wicked_geezer's Avatar
wicked_geezer
damn the exact same shit happend to mine i when i red line my gears shifting gets hard but the gears go in sometimes they grind...i know its my clutch now i just need to get payed to buy one...btw its a 96 gsr and mine has 92,000 u should try to bleed the clutch that helped me a little bit
