Stock springs from other hondas fit on my 2G?
Will stock springs from other Honda vehicles fit on my 2G(1991 Integra LS 2dr)?? I checked the faq, but spring rates vary by generation. What would happen if i used a different spring rate on mine? What other "honda car" springs will fit my integra? Thanks!!!!
Most other Hondas of that year vary greatly with regards to weight. Most likely the spring rates will all vary. If you find a vehicle with a weight similar to yours, you'd be on the right track.
Check vehicle weight, then check the bolt patterns. This way you don't run around the barn ten times looking for a pattern.
I assume your shocks are problematic, in which case, your best bet is to hit up junk yards for your same make/model. It'll save you time and most likely... money.
