Little problems or maybe big!!
Old Sep 28, 2005 | 05:57 AM
honura's Avatar
honura
Seni
Default Little problems or maybe big!!
Hey guys. I am having issues. My driverside mount is Fcked. The stud that goes on the block the actul bolts that screw it onto the block got loose somehow and now it stripped the threads. How can I fix this? Without having to pull it apart and send it to a machine shop? I was thinking rethread it a bigger size but can I? Do they sell tappers that big'? HELP!!!!!!!
Old Sep 28, 2005 | 06:04 AM
teg92's Avatar
teg92
WHAT OK YEAH!
that happend to be too about a year ago, I just re threaded it and put a big bolt in there and it worked fine.
Old Sep 28, 2005 | 06:23 AM
honura's Avatar
honura
Seni
Yeah that's what I think that's what I am going to do. Actually the top two screws one broke in ½ the other stripped and the lower one is stripped as well. Ahhh man and it messed up my rear mount, and now my driverside axel is clicking even while driving straight. Ahh man I pissed off man.
Old Sep 28, 2005 | 06:47 AM
honura's Avatar
honura
Seni
So this means you also had to make the holes on the stud bigger in order to make the wider screws fit correct?
Old Sep 29, 2005 | 11:37 AM
honura's Avatar
honura
Seni
No one else can help me?
Old Sep 29, 2005 | 01:14 PM
mean-azz-acura's Avatar
mean-azz-acura
Grand Sport-Race
dude, it sucks but i wouldnt stress too much about it. id talk to some of your buddies about it because tools for situations like yours arent a commonly used thing so theyll most likely be more than willing to lend it. i think they make suttin called an easy out to pull broken bolts, not positive though. what im thinking of you drill a hole into whats left of the bolt, then theres like a reverse threaded screw that actually loosens the remains of the bolt as you tighten the screw. ask around an lemme know...
Old Oct 4, 2005 | 12:29 PM
honura's Avatar
honura
Seni
Well I got some bolts to go in there with maybe 2 washers each. Seems to be holding up fine. Even after a few peelout test's and all. Thanks god only the first 3/4 of the threads where stripped. sheeewwww I hope it holds up if not then I found a shop around here that sells each tapper seprate with a handle for each one. So that makes me feel a little better as far as cost. Thanks for the help guys.
