D4 light blinking on dashboard
Old Sep 26, 2005 | 05:33 PM
crazygamer's Avatar
crazygamer
Default D4 light blinking on dashboard
Something seems to be wrong with my car - '94 Integra LS Auto. The first thing I noticed was the D4 light (on the thing that shows you what gear your in) was blinking, even if I put it in 3rd. Also, the needle on the speedometer wasn't working. A while later the check engine light also came on. However, everything else seems to be fine. Does anyone know what this could be? I'm going to go look up anything I can but if someone could help I'd appreciate that.
Old Sep 26, 2005 | 06:07 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Grab the CEL code and we'll do what we can to help.
https://www.honda-acura.net/forums/s...52&postcount=7
That link shows how to jump the CEL terminal and retrieve the code.
https://www.honda-acura.net/forums/s...1&postcount=10
This link shows the OBD-1 codes for your vehicle. Look up the CEL code on this chart and get back to us.
Old Sep 26, 2005 | 06:50 PM
crazygamer's Avatar
crazygamer
I'm getting 1 long blink, then 7 short, then followed by another 6 short, so I'm guessting VSS and ECT. Any ideas other than having my mechanic check it out?
Old Sep 26, 2005 | 07:07 PM
TheOtherDave™
Apathy Kills
I figured that the Vehicle Speed Sensor might be a part of this.
Either the signal from the VSS isn't making it to the ECU or the sensor itself is dead.
My money is on the sensor.
Coolant temp, though... :thinking: That's odd...
Has the coolant temp "gauge" been erratic or non-responsive? Is the coolant level within the normal range?
Old Sep 26, 2005 | 08:17 PM
crazygamer's Avatar
crazygamer
It seems to be fine. It didn't work when I got the car but that was due to a falty thermostat. Once I got that replaced the gauge has always been a little below the middle when the car is warmed up. The coolant level was also within the normal range last time I checked it (no more than a month ago).
I think I'm going to take this to my mechanic tomorrow and see what he says. Does anyone know how much the sensors are at an Acura dealership?
