92 integra ls
Old Sep 26, 2005 | 12:49 PM
Brebos's Avatar
Brebos
Default 92 integra ls
I think my coolant fans do not work cause my car overheats after about 30 miles and have not seen the fans move. Where is the engine coolant temperature switch located or the sensor..rrrr i need help. My fans dont work and car overheats...what should i do?
Old Sep 26, 2005 | 01:21 PM
tgansert's Avatar
tgansert
is all good
The fans not working wouldn't cause your car to overheat. Check your coolant level and thermostat.
Old Sep 26, 2005 | 01:48 PM
Brebos's Avatar
Brebos
Really? coolant fans not coming on would make it....not cool? yes of course i know this but why are my fans not coming on?
Old Sep 26, 2005 | 01:49 PM
Brebos's Avatar
Brebos
BTW checked coolant and thermostat doesnt control the fans. I also checked all fuses. I just need to know what turns the fans on and if thats the problem.
Old Sep 26, 2005 | 02:23 PM
Swisher's Avatar
Swisher
If your cruisin on teh freeway the fans wouldnt help but if your in traffic or idling, thats when the fans kick on.
What type of driving are you doing when it overheats? Does the fan come on when you turn the A/C on?
Old Sep 26, 2005 | 02:50 PM
Brebos's Avatar
Brebos
The fans do come on when the A/C is on. Wheew! i thought it was a fuse prob or relay or something. I just bought the car and the only time the fans come on is when the A/C is on. Please help!
Old Sep 26, 2005 | 03:13 PM
tgansert's Avatar
tgansert
is all good
Then your thermostat is gunked up or fried. You can search HAN for correction methods.
Old Sep 27, 2005 | 12:25 PM
JETSPD1477's Avatar
JETSPD1477
O RLY?
fan switch is located on the thermostat housing. if your fan isn't turning on when the car is heating up then i'd change the switch. wether or not the thermostat is bad your radiator fan should be turning on.
Old Sep 27, 2005 | 05:08 PM
Swisher's Avatar
Swisher
I agree with this, i just wasnt sure if this car had a fan switch or not
