A/C Condenser Belt Question
I have a '95 LS integra...
Long story short my A/C went out, I check the condenser belt and it was gone, so apparently it fell off. The problem is the tension/idle pulley (bracket and everything) came unscrewed. So I assume that is what caused the belt to fall off. I found the pulley, luckly, but the bolt to the engine is nowhere to be found... is this bolt something that can easily be found?
Also... how hard is it to change the condenser belt? it looks like you would have to remove the whole condenser itself.
Thanks in advance.
Thanks in advance.
The bolt can probably be found at a dealership.
Installing the belt isn't that hard. I believe that you have to remove the P/S and alternator belts first in order to slip the A/C belt on. Just slip the new one on and tension it and it should be fine.
