problem with backup lights
Old Sep 22, 2005 | 11:04 AM
kakasaka's Avatar
kakasaka
Default problem with backup lights
My backup lights arent working....
I have a 2000 Integra LS
5 speed
Acura said it could be the switch or the fuse....
Im having trouble locating the fuse because when i bought the car, it came with no manuals, or the fuse cover... i fixed it but it doest have the fuses and where they are located...
is it in the under the hood?
or located on the drivers side
any help would help me....
Old Sep 23, 2005 | 07:38 PM
JKAE's Avatar
JKAE
2000TEGLS4DR
probably under the drivers side-get yourself a chilton guide book and youll be fine
Old Sep 23, 2005 | 10:24 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Check out the PDF version of the service manual in the forum sticky. It will provide fuse numbers and function. The correct fuse is in the under-dash fuse box and is #15. If it were bad, however, your clock and gauges wouldn't function.
The backup switch is located outside the tranny and may have been unplugged. That is what I would check first.
