mixing???
Old Sep 19, 2005 | 11:15 AM
Zak's Avatar
Zak
zak tha mak
Default mixing???
okay so i just switched to synthetic over the weekend, i wanted to put mobil 1 in but all the place had was valvoline. i was just wondering if the oils are the same viscocity is it okay to mix them?
Old Sep 19, 2005 | 11:22 AM
tgansert's Avatar
tgansert
is all good
You can mix synthetics as long as they are the same type 10-w30 for example. Just don't make a habit of it.
Old Sep 20, 2005 | 09:45 AM
Zak's Avatar
Zak
zak tha mak
good good, thanks for the info
Old Sep 20, 2005 | 09:52 AM
TheRooster's Avatar
TheRooster
Former Senior Member
It's generally not a good idea. Each brand uses its own chemicals and detergents, so two motor oils of the same grade are not necessarily the same.
Old Sep 20, 2005 | 02:39 PM
Zak's Avatar
Zak
zak tha mak
not necessairly the same huh, so to be safe i should probably just continue putting valvoline in?
Old Sep 20, 2005 | 04:07 PM
chewie's Avatar
chewie
change to mobil 1 for your next oil change.
