Hello, I I Think I Might Have A Bad Main Relay
Originally Posted by raul95020
i know theres two realys under the sterring wheel, theres a black and bigger brown one, and the brown one is the main relay right, or is it the black one?
one guy once told me that he had a clutch problem that sounded just like mine and it also had to do with the heat, do u know anything about that kind of problem?
Originally Posted by Tanker
The main relay is the one with seven wires. There are a bunch of relays that looks almost like the main relay. The one you're looking for should go click and then a second later go click when you turn the key on. Feel it with your finger.
If your clutch switch broke it won't start (no clicks, nothing.)
ok, thanks, i felt it and i could tell wich one
