high flow fuel rail
Old Aug 31, 2005 | 12:57 PM
kidkillkid's Avatar
kidkillkid
Default high flow fuel rail
does changing to a high flow fuel rail bennefit my car? is it really worth installing?
Old Aug 31, 2005 | 01:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
No.
The stock one can handle 600 hp, so the only reason to change it would be bling factor.
Old Aug 31, 2005 | 03:26 PM
B18C Turbo's Avatar
B18C Turbo
bling factor=600 whp :chuckles:
1turbodc2's Avatar
1turbodc2
got boost?
waste of money
Old Aug 31, 2005 | 03:58 PM
tgansert's Avatar
tgansert
is all good
Put it together with a 18" high aluminum wing and you can get up to 15hp.
Old Aug 31, 2005 | 04:08 PM
delsol161's Avatar
delsol161
hehehe, they are useful in all those 1,000 whp tuners cruisin' around town
Old Aug 31, 2005 | 04:25 PM
tgansert's Avatar
tgansert
is all good
I have three cars just like that! They sit next to my Champ car (which, BTW, needs a spoiler, unlike every other ricer that has one and wishes he could make use of it).
Old Sep 16, 2005 | 08:43 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Originally Posted by Däs Schmoo
No.
i have a couple questions concerning the fuel setups of integras:
1.) is there a difference between the ls fuel rail and gs-r fuel rail?
2.) what about the fuel pump, worth upgrading to aftermarket?
3.) if i raise the compression to around 12.0:1 will i need any of these? (fuel pressure regulator, fuel pump, fuel rail, etc.)
Old Sep 16, 2005 | 09:18 AM
Provocateur
On permanent hiatus
1) No
2) If you have the mods that require extra fuel, a higher volume fuel pump is a good idea. More than likely a mild N/A build will not even come close to needing the extra fuel. In a boosted application, it is good insurance against leaning out and blowing the motor.
3) Probably not. You will probably need some larger injectors and a standalone to handle the fueling.
Old Sep 16, 2005 | 01:48 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
1) No
thanks a lot. this is starting out as an ls with the bottom end built. then i wanna put my built b16 head on it. but i still need to install the cams and do some machine work to the head so i wanna get it in the car with the ls head for now. what size injectors do u think i'd need to upgrade to? u think '96 prelude vtec injectors would work? i know they supply more fuel than the stock integra injectors. or would u suggest upgrading more.
