No power coming out of the fuel injectors - HELP!
Old Aug 26, 2005 | 02:43 PM
knight akkord's Avatar
knight akkord
Default No power coming out of the fuel injectors - HELP!
Hey guys, need help - no power signal coming out of the fuel injector wiring. I've changed the crank shaft precision sensor and the distributor already. Car does not start or run, just turns over as if it's out of gas. It's a 1994 Integra LS. I have heard that I should check the relays (there are two)....how do I find out where they are and how to check them? My car has been sitting for 2 weeks b/c of this ......HELP!!!.....Thanks!
Old Aug 26, 2005 | 04:26 PM
raihan.f1's Avatar
raihan.f1
Used to have the same problem. Replaced the main relay yesterday in my Integra & it starts perfectly. It is under the dash board on the drivers side.
Check this out
http://www.marklamond.co.uk/howto/el...main-relay.htm
