psi ?
Old Aug 23, 2005 | 02:51 PM
95ac.teg's Avatar
95ac.teg
Default psi ?
nub question . Whats psi ?
Old Aug 23, 2005 | 02:54 PM
ACS S3 3.0's Avatar
ACS S3 3.0
Honda Two Thhhhousand
pounds per square inch.
Old Aug 23, 2005 | 05:05 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Pounds per square inch.
It is a measurement of pressure that applies to pneumatics (air) or hydraulics (fluid).
Most commonly, it is used to quantify the amount of boost a supercharger or turbocharger is producing at the intake manifold of an internal combustion engine.
Old Aug 23, 2005 | 05:09 PM
b00gers's Avatar
b00gers
Or the amount of air in your tires h:
dubcac's Avatar
dubcac
I
It's also used as a measurement of stress in a material. And I think it's more commonly used to quantify the amount of air inside a tire.
h:
Old Aug 23, 2005 | 05:11 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Google -> define: psi
Refers to the unit of measure of pressure Pounds per Square Inch.
www.egl-neon.com/glossary.htm
pounds per square inch; a common measurement of air pressure.
http://www.lakesidepress.com/pulmona...a/sectionq.htm
Pounds per square inch, the common unit of measurement for pressure. Normal atmospheric pressure at sea level is 14.7 psi.
www.parttrackers.com/auto_glossary/pq/
Abbreviation for pounds per square inch.
www.ssqi.com/Library/glossary.html
Pounds per square Inch.
www.newyorkerboiler.com/glossary.cfm
Indicator of one or more pollutants that may be used to inform the public about the potential for adverse health effects from air pollution in major cities.
www.epa.gov/OCEPAterms/pterms.html
www.solutionsforpower.com/glossary.html
Pounds per square inch. A unit of pressure. At sea level, the earth's atmosphere exerts 14.7 psi.
www.dhs.ca.gov/ohb/HESIS/utsgloss.htm
Measure of the load pressure of one commodity on another. Atmospheric pressure at sea level is 14.696 psi with Fluid pressure (liquid & gas) being measured in terms of pounds per square inch absolute or pounds per square inch gauge.
www.yourwebassistant.net/glossary/p15.htm
need more? h:
Old Aug 23, 2005 | 05:29 PM
sherwood's Avatar
sherwood
I missed Sean
Packet Switch Interface? Psychological Society of Ireland?
