Rattle after new clutch and flywheel--HELP!
After installing an Exedy organic clutch (from ebay) and an ACT streetlight flywheel, I am getting a rattle/rumble while slipping the clutch. Any ideas or experience are greatly appreciated.
-ct
-ct
On permanent hiatus
Did you clean the pressure plate and flywheel mating surfaces? If you don't clean the protecting oil off, it will have some nasty clutch chatter.
On permanent hiatus
Originally Posted by VTEC-Power
Hey Shmoo, didn't you say you had clutch chatter?
What is tripping me out is the lightweight flywheel sounding like a sack of marbles in my transmission when I engage the clutch. I guess it is normal.
Yes, a little bit. It is normal with an upgraded clutch.
I am about to put a new clutch in. I'll make sure i keep surfaces clean and grease the bearing. Exedy clutches are okay right? How much you guys pay for yur new clutches? I just want a standard one that'll last a few years
On permanent hiatus
Originally Posted by Sense-A
ahahaha :lmao:
I paid $604 shipped for my ACT HDSS and 8.8lb Prolite flywheel. An OEM will run much less and if you just resurface the flywheel, it should only run an additional $20-30.
