fuel pressure
Old Aug 16, 2005 | 09:19 PM
97 integra's Avatar
97 integra
Default fuel pressure
when i accelorate hard my car smokes, i have been told by several people this is caused by the car running rich. if this is so can i adjust the fuel pressure to correct? and if i can do so is the stock fuel pressure regulator adjustable?and how do do it?
Old Aug 16, 2005 | 09:32 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What color is the smoke?
Are you missing oil when you change your oil?
If it is a stock engine, it is highly unlikely it is running rich enough to cause smoke. Sounds like toasted piston rings to me.
The stock fuel pressure is not adjustable and putting an adjustable fuel pressure regulator isn't going to help the problem. You would need something to lean out the fuel ratios like a VAFC, but I find it would be highly improbabable that you are running overly rich.
Old Aug 17, 2005 | 04:55 AM
97 integra's Avatar
97 integra
the motor is stock and the rick condition is what acura mechanics told me. they also said the rings should be fine that all honda motors smoke when u accelorate hard, it uses oil but not as much as the amount of smoke i have seen.
Old Aug 17, 2005 | 06:05 AM
teg92's Avatar
teg92
WHAT OK YEAH!
the stock regulator is not adjustable, you would eaither have to get a AEM or B&M fuel pressure regualtor, you should also get the B&M fuel pressure gauge
Old Aug 17, 2005 | 01:13 PM
Black92GSR's Avatar
Black92GSR
since when? my engine does not smoke at all, infact if I overfill it when changing oil it will be like that until the next oil change...(but I only have 10K on my rebuild).....
What color smoke is coming out.... and what do you spark plugs look like, are they black or white?
Old Aug 17, 2005 | 03:51 PM
teg92's Avatar
teg92
WHAT OK YEAH!
well you have a rebuilt motor it shouldnt smoke
Old Aug 17, 2005 | 07:11 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
my car smokes a shit load when i get passed 6000 rpm...but i know im running rich like crazy, and i have charts to prove it. My car doesn't burn much oil if it burns any at all.
Old Aug 18, 2005 | 10:29 PM
speeda's Avatar
speeda
Easiest to find out if your car burning oil or not is a compression check to see the rings condition. And in order to adjust the fuel pressure you need to get an adjustable fuel pressure regulator to do so. Good luck...I hope your car i simply running rich and not the rings are out and need to be replaced.....
