Door Lock Problem...Please Help
Old Aug 15, 2005 | 04:48 AM
tony852's Avatar
tony852
Default Door Lock Problem...Please Help
Okay, I have just discovered a problem with my driver side automatic door locking mechanism. Just the other day, I started up my 97 GSR and as you most know, when you start to go the locks automatically lock the door for you. So when this happened (it scared the $%#@ out of me) it didn't lock, and it made this loud popping sound like a machine gun. Almost like something was stopping it from locking. Even when I get out of my car and I try to lock my door with my alarm keypad, the door won't lock. I have to manually stick the key in the hole to lock the door. So if anybody has ever had this problem or knows what and how to fix this...Please Enlighten Me. Thanks for the help!
Old Aug 15, 2005 | 09:56 AM
AdNaMa585's Avatar
AdNaMa585
Amanda Backwards
My 95 does that. Its sporatic though so I usually just ignore it. I may be wrong, but I thought it was the alarm that caused the doors to lock when you start the car.
Old Aug 15, 2005 | 10:09 AM
tony852's Avatar
tony852
You might be right, that the alarm causes the doors to lock when you start the car. But that's not my problem, my problem is that the door won't lock when I hit the lock button on the keypad. I have to manually put the key in and lock it...I shouldn't have to do that. Why won't the dumb thing lock?....It was just working the other day!
Old Aug 15, 2005 | 01:47 PM
AdNaMa585's Avatar
AdNaMa585
Amanda Backwards
Maybe you need a new keypad. However, since you said that it didn't lock that one time, but made that noise, makes me wonder if there's a wire messed up somewhere. If you got it installed somewhere, I'd take it there and ask them.
Old Aug 15, 2005 | 02:23 PM
VPUPPY's Avatar
VPUPPY
take your door panel off and check the metal bars and actuator. the actuator is a little motor that moves your door lock. its sounds like something is broken mechanically in the door.
Old Aug 15, 2005 | 03:06 PM
gasper44's Avatar
gasper44
Try just doing it manually, to lock the door while it is OPEN, you must pull the inner door handle out and then push the lock button. You may k now this, you may not, but you wont believe how many integra owners I have had to tell this, they all thought their lock was broken. Your prob. is a little different, but maybe somethigns just out of sync.
Old Aug 17, 2005 | 01:48 PM
00SSblueAEMV2's Avatar
00SSblueAEMV2
I just posted a thread about this too. i have no idea what could be wrong, i dont have an alarm or the oem keyless entry just the key. It scared the shat outta me too but mine is on the passenger door. i really wish i could find out whats wrong i'm gonna take my door panel off this weekend if it doesnt stop. the odd thing is is that my locks were working fine today but it was still clickin like a machine gun hmm... weird
Old Aug 17, 2005 | 01:53 PM
94JR's Avatar
94JR
Sometimes my driverside will try to lock but only makes it halfway and goes back to the unlocked position. I've taken the door pannel off but it worked fine. seeing as it only does it accasonally I can't say if the door cover is the problem or not.
Old Aug 17, 2005 | 04:40 PM
VPUPPY's Avatar
VPUPPY
that usually happens on most hondas if the drivers door is open. if the door is closed, thats a different story.
Old Aug 17, 2005 | 04:50 PM
94JR's Avatar
94JR
Now that i think of it the door was open when it did that.
