One of the most noobtastic Q's I've had in a while... Tire Pressure.
Old Aug 5, 2005 | 12:37 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
Default One of the most noobtastic Q's I've had in a while... Tire Pressure.
What should the tire pressure be set to in my tires?
I need to go get my wheels balanced, and i'm gonna just have the rotate and air them up while they're at it... but i've heard a lot of people say that people over do it when they're just putting air in...
(don't remember who it was that said it, but i recently remember reading someone say "every time I have someone fill my tires I end up letting out about 12lbs of pressure" or something like that.)
So what should I have the tire pressure set to?
Stock GSR Rims, with generic all-season tires, if that makes a difference.
Thanks as usual.
Old Aug 5, 2005 | 12:40 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
35 at the most. 30-35 is your best bet. I run 34/35 in mine daily.
Old Aug 5, 2005 | 12:42 PM
94civicEX's Avatar
94civicEX
I got worms.
Check your max psi on your tire. I usually go minus 3-5 of that.
99 Integra GSR
06 TSX
duck squad member #00003
Old Aug 5, 2005 | 12:53 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
So... yeah, it's been a while since i've read off tire codes...
They're Dunlop Studless,
195/55r15 85q (I think it was a q, lil weird lookin' tho)
Max Press. 300kpa (44psi)
So I should have them put like 39-40psi into the tires?
Old Aug 5, 2005 | 12:57 PM
csprague's Avatar
csprague
Warthog Pointyhead
between 32-35 psi
Old Aug 5, 2005 | 01:02 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
Alright guys, thanks for the help, sorry for the mental retardation... haven't dealt with tire problems since auto class in highschool. =P
Old Aug 5, 2005 | 01:34 PM
Redblurr's Avatar
Redblurr
Piů Allentato
i usaully run 39-40 p.s.i.
Old Aug 5, 2005 | 03:42 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Christ, you guys run an insane amount of pressure.
:noes: 40psi is way too high.
Above 35 psi, ride quality is horrible.
Tire wear is concentrated on the center of the tire.
The contact patch is reduced, and a savage pothole can ruin your day.
The Owner's Manual recommends 29 psi front/rear if I remember correctly.
On stock tires, I would stay within 5 psi of their recommendation.
Since my suspension setup is already pretty firm, I run 30 front, 28 rear.
On interstate treks, I go up to 32/30 and soften up the shocks a bit.
This is on 205/45/16s, however.
Old Aug 6, 2005 | 06:25 AM
Illegal B16's Avatar
Illegal B16
New Zealand
35 all day, at the track I dont have skinnies so i put the rear at 40.
Old Aug 8, 2005 | 04:53 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
ended up having em 35front, 33 rear... or vice versa... i just woke up.
