Integra fuel pump kill switch??
Old Aug 4, 2005 | 08:15 AM
sweetlou03's Avatar
sweetlou03
Default Integra fuel pump kill switch??
is there a kill switch installed in the 95 integra gs-R model?
Old Aug 4, 2005 | 08:17 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
From the factory, not to my knowledge.
Old Aug 4, 2005 | 08:22 AM
sweetlou03's Avatar
sweetlou03
i thought so my car wont start
Old Aug 4, 2005 | 08:25 AM
94civicEX's Avatar
94civicEX
I got worms.
Battery? Aftermarket alarm?
99 Integra GSR
06 TSX
duck squad member #00003
Old Aug 4, 2005 | 08:27 AM
sweetlou03's Avatar
sweetlou03
Do you think maybe the fuel pump relay or the ignition switch.... Im a chick i dont know too much about cars LOL....the battery is fine we tested it with a reader thingy....
Old Aug 4, 2005 | 08:28 AM
westcoaststyle
Any fuses blown? What led up to this - any additions or oddities?
Old Aug 4, 2005 | 08:30 AM
sweetlou03's Avatar
sweetlou03
I got a 95 integra... saturday it started acting up.. wouldnt start cranked it a few times then it did.. next day started up left the store came out didnt start... cranked it a few times then it started ... monday morning started right up went to work left work didnt start cranked it for about 20 min then it started... had a buddy look at it cause it was dead at work again the next day tested the battery its good all the fuses are good... no power to the fuel pump or instrument panel but the car cranks.. battery is good and all the fuses have power exceot # 18 and 24 one of which is controlling the ignition.. Could it be my fuel pump relay or a bad ignition switch doing this...
Old Aug 4, 2005 | 08:33 AM
teg92's Avatar
teg92
WHAT OK YEAH!
I say bad fuel pump realy, Happens to my car to i replaced the fuel pump and it still does it once in a while. i will be replacing the realy some time soon. I think they cost about $80.00
westcoaststyle
If your fuel pump and cluster are not working either, it could be a lot of things. Did you check all the fuses in the box in the engine bay as well? There are relays in there that could use inspection as well.
Old Aug 4, 2005 | 08:38 AM
sweetlou03's Avatar
sweetlou03
yea all the fuses are good i dotn understand the car starts when it wants too LOL.. like this morning I got to work cause I left it there last night and it started right up no problem.. this afternoon went out to drive it home wouldnt start... the only thing is the thing the fuses go into i dont know what you call it well the power going out of # 18 and 24 on the fuse box no power is being given out to there its the one for the ignition and fuel ..... oh and theres no fuel pressure going to the engine when im cranking it...
