Replaced headgasket, need help
Replaced the headgasket on a 91 integra gs, (which btw, was a nightmare) and I got everything back together--finally got the timing belt and tensioner to cooperate, hooked everything back up, turned on the car, and it barely idles at 100 rpm, jumps between that and 400 rpm, and then the car dies. There is also a rhythmic thumping sound --aka, doesn't sound normal, when you rev it. Any ideas? I don't really want to take everything back apart again...please help!
yes, after about 4 times of having the timing belt on and back off, the timing was dead on. the tension was great. every thing is plugged back in, everything is checked and double checked..
It still seems like your timing to me...you might be off a tooth. I'd recheck that. Even just one tooth could cause the problems you're seeing.
How is the tension in the belt? Is it loose, or is it ok? Check that, because if it's loose, that could cause you to jump teeth at the cam gears, and your timing to be off. And like other people said, check your sensors too.
I've just been through the same thing you are going through. First I realized my spark plug wires were plugged in incorrectly, so make sure they are right. Then I was having a big problme with overheating still. I was sure the timing was correct, but after breaking down and taking it to a shop, my timing was the problem
