The new b20 issue
Old Aug 1, 2005 | 10:01 AM
honura's Avatar
honura
Seni
Default The new b20 issue
Ok I pulled the head of my b20vtec and Found nothing wrong with the valves and or pistons. I did infact find out that the injector closest to the distro was sparying a shit load of gas. At times it's normal then it just starts shutting a shit load. Then when you leave everything alone you can see it kinda like bubbling up or whatever like it wants to shot some gas out. I changed the injector and it does the samething. It's just that one that is going crazy. I took the other 3 injectors and put it into that plug and it's the samething. Please help!
Old Aug 1, 2005 | 10:09 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I say wiring. You likely have a short in the line somewhere or for some reason your ECU is not telling that injector to shut all the way (that's a guess). If you've determined that it's not a mechanical issue, then the next step is electrical.
Old Aug 1, 2005 | 10:58 AM
dubcac's Avatar
dubcac
I
I agree...wiring/electrical.
Old Aug 1, 2005 | 06:30 PM
B18C Turbo's Avatar
B18C Turbo
yes it sure sounds like that plug is bad and/or the yellow and black wire leads are crossed. I have seen this and it causes the problem you've mentioned. Try replacing your fuel injector wiring harness, I can almost gaurantee this will solve the problem.
