New ECU problem!
Old Jul 31, 2005 | 05:10 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
Default New ECU problem!
Ok just plugged in the new obd1 ecu in my 96 integra. Started up fine and i let it set for about 3-4 minutes then i tried to take off and when i gave it gas it just died. then i tried to start it and it took me about a minute for it to start and then it finally started. Then i was like ok whatever so i gave it some gas and it almost died again. Now its sitting in the driveway idling. Do i need to reset the battery or the ecu fuse? HELP!
Old Jul 31, 2005 | 05:20 PM
teg92's Avatar
teg92
WHAT OK YEAH!
well your using an OBD1 ecu in an OBD2 car
Old Jul 31, 2005 | 05:26 PM
aboobybobpleez
i have the obd2a-obd1 harness......
Old Jul 31, 2005 | 07:04 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Is it throwing any CELs?
I would double check that harness since that is usually the problem with OBD2 to OBD1 conversions.
Old Jul 31, 2005 | 08:00 PM
dubcac's Avatar
dubcac
I
Is the ECU running an aftermarket chip in it? The problem is either the harness or the ECU. Try finding a friend that has either a known good harness or ECU, and put in one of them and see if that fixes the problem.
Old Aug 1, 2005 | 11:56 AM
aboobybobpleez
Problem fixed....hopefully...Yea it's a chipped obd1 ecu and after i posted this i pulled the ecu fuse and let it sit for about 15 minutes, then i put the fuse back in and she started right up. weird? my obd2 ecu was throwing a 65 code but now its gone and the ecu runs very well. But yesterday after running it for a while i shut the car off and when i tried to start it up it took about 30 seconds and i thought i was screwed again but she ran good all last night no problem and now i have some more "umph"
Thanks
Old Aug 1, 2005 | 12:07 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Was your fuel level low that last time you tried to start it? Hondas/Acuras are notorious for taking a bit longer to start on a low fuel tank...
Old Aug 1, 2005 | 01:26 PM
aboobybobpleez
ok...maybe i spoke too soon. Went for a drive just a little bit ago and the car likes to die at lights and dosent want to start anybody else ever go through this with a chipped ecu?
Old Aug 1, 2005 | 01:31 PM
Provocateur
On permanent hiatus
What program is it chipped with?
Old Aug 1, 2005 | 01:40 PM
westcoaststyle
A lesson to anyone reading this and thinks that throwing an untunable chip on an ECU is a good idea... think again. h:
