TEG Brakes...
Old Sep 4, 2002 | 04:08 AM
SlowCivicHmm's Avatar
SlowCivicHmm
Default TEG Brakes...
what size are 94 and up teg brakes front and rear...
what all can my eg benefits from the teg suspension...
I know that the entire front brake asembly as well as rear with sway bar....do tegs have front sways???
I'll be getting a full teg suspension...I mean everything so what should I take off and put on my car....
Basically I'm getting a rolling suspension ..muaahahahah
Old Sep 4, 2002 | 04:24 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Tegs have 10.4" front discs and 9.5" rears. The front swaybar on 94-97 (I think...might be up til '96 or '98) RS/LS/GS is 22mm, everything else is 24mm. Rear, all of em have a 14mm except the ITR which is 22mm. The lower control arms, trailing arms, hubs, brakes and swaybars should all bolt up. If you use the teg shocks/springs it will raise your car up about 3/4 inch.
Old Sep 4, 2002 | 06:25 AM
ShaolinLueb's Avatar
ShaolinLueb
get soem bigger brakes in the back so you can left foot brake it thats advanced technique.
Old Sep 4, 2002 | 10:17 AM
SlowCivicHmm
haha...left foot braking would be ****ing awsome..but I just paid a ticket today don't need anymore...lol
Thanks bro for the info...what if I just use the struts and not the springs...I have sprint performance drop springs...
any idea how big my vx rotors are up front??
Old Sep 4, 2002 | 07:08 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
VX rotors are 9.5" but thicker than teg rears. Keep in mind that when you swap over to teg brakes you get bigger calipers as well as bigger rotors.
You could use the teg shocks with the Sprint springs but you won't see enough of a difference to make taking the springs off the Civic shocks worth it.
Old Sep 4, 2002 | 07:47 PM
Taiwanze7's Avatar
Taiwanze7
I thought the RS/LS/GS 2DR coupe was only 12.8mm rear swaybar, the GSR is and sedans have 14mm rear
Old Sep 4, 2002 | 11:14 PM
SlowCivicHmm
I"m swap out the struts cuz my civic struts are blown....so I will see an improvement.......
my front rotors are 9.5 and the teg rears are 9.5 also?? can I use my vx front rotors on the teg rears?? cuz I have brembo slotted/drilled rotors...
what size rims to I need to clear the new calipoer...cuz I doubt my 13in vx alloys will do the job!!
Thanks guys keep the info coming....
themonsteraria
92+ Civic/EL & Del Sol
3
Aug 21, 2009 03:36 PM
EK_RACER
Oct 3, 2003 01:34 PM
NoRiCeHeRe
3
Jul 11, 2003 12:32 PM
Bakeoff
3
Jul 1, 2003 07:00 PM
sheehan024
Aug 5, 2002 04:56 AM
