ok b20VTEC part2
Old Jul 29, 2005 | 10:14 AM
honura's Avatar
honura
Seni
Default ok b20VTEC part2
Ok I took off the head and all the valves seem to be fine. I looked at the bottom and everything seemed ok. What do you think? When I installed the B20VTEC motor into my tegra it seemed to fire up just fine then the next day you can see that the Cylinder next to the Distro was not firing. YOu can see gas coming out the muffler and also if reved past 4k you can hear like a rock or something of that mature shacking around. But there is nothing in the motor. Please help!!!!!
Old Jul 29, 2005 | 10:56 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
pics
Old Jul 29, 2005 | 12:55 PM
VTEC-Power's Avatar
VTEC-Power
is the rock like a ticking noise?
Old Jul 29, 2005 | 05:29 PM
honura's Avatar
honura
Seni
I will have pics in a little while.
noise is wierd. it's not a knocking noise. hard to explain
Old Jul 29, 2005 | 06:47 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Piston slap?
Rod bearing seizure?
Con rod bolt failure?
Main bearings out of round?
There are many critical tolerances that could be the source of a knocking or even a dull popping sound... pics would definitely help?
Forgive me, but were you able to get compression numbers before taking the head off? h:
Old Jul 29, 2005 | 07:51 PM
honura's Avatar
honura
Seni
YEs I got a 210 on that one cylinder.
Old Jul 29, 2005 | 08:16 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
problem fixed!?
Old Aug 2, 2005 | 12:45 PM
integragation's Avatar
integragation
Default check the ECU
CHECK THE ECU AND HARNESIS
Old Aug 2, 2005 | 04:53 PM
VTEC-Power's Avatar
VTEC-Power
well can you describe the sound better, maybe record it???
Old Aug 3, 2005 | 12:19 AM
honura's Avatar
honura
Seni
Well I was putting the head back together and it turns out Im getting some ITR cams this frieday. So I left everything along and Im gonna finish working on it this frieday. I will keep everyone posted. Thanks
