Advancing Ignition Timing
Old Jul 28, 2005 | 07:47 PM
speeda's Avatar
speeda
Default Advancing Ignition Timing
I have been looking around and it seems that advancing ignition timing will give better low end power. I have tried this myself and it seems to work a bit. However, how much can you advance the timing and whats the best way to do this without a dyno machine in the back yard?
Old Jul 29, 2005 | 12:29 AM
dubcac's Avatar
dubcac
I
You can advance it until you ping...I wouldn't go past 20 probably.
Old Jul 29, 2005 | 05:13 AM
B18C Turbo's Avatar
B18C Turbo
you need a timing light obviously. Hook it up and fire it at your crank pulley while the engine is idling at 750 rpm +- 50rpm's. The red mark is BTDC 16 degrees and white is 0. Green is like 14 i think, check the helms, but you want to be as close to the red as possible.
Old Jul 29, 2005 | 05:44 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It's worthless. I tried this years ago thinking I would get more 'power', but all it does is hurts your gas mileage.
Old Jul 29, 2005 | 06:16 AM
teg92's Avatar
teg92
WHAT OK YEAH!
did it to "sp00nfed" car last week and it didnt really do anything so he put it back to stock.
Old Jul 29, 2005 | 01:00 PM
Mac8008's Avatar
Mac8008
theoretically, adv your timing should increase gas mialage
Old Jul 29, 2005 | 01:27 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
yup i just put it back to how it was...im actually gonna buy a timing light so we can check where it is exactly. I don't know if i'd recommend advancing it
