cluster removal?
Old Jul 19, 2005 | 10:13 AM
blkstangman88's Avatar
blkstangman88
Default cluster removal?
how do you remove the cluster out of a '91 integra? i cant get the black trim off.
Old Jul 19, 2005 | 10:57 PM
blkstangman88
what, nobody knows how to remove it?
Old Jul 20, 2005 | 04:47 AM
vanicult's Avatar
vanicult
Default not too difficult
I did it on my 92 integra.
There are 5 screws to remove.
2 at the top of the cluster, 1 behind the heat control, 1 behind a small plastic cover on the right next to the central air vent of front passenger seat.
There is another screw on the left, near the steering wheel.
Once the 5 screws are out, the real difficulty is to disconnect the connections at the back of the cluster: 2 electrical and 1 speedometer cable.
if your hands are small, you might just slide yours at the back and disconnect it. Otherwise, I disconnected the speedometer cable from the engine and pulled the cluster out.
Now you can disconnect all your cables.
Good luck man!!!
