people with 1 piece header....
Old Jul 16, 2005 | 09:00 AM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default people with 1 piece header....
do you have to take off anything to install it. I mean like the AC fan...so you can fit it up from the bottom.
Old Jul 16, 2005 | 09:26 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i think you would probebly need to remove some compontents to install the header. have you tried going in from the top?
Old Jul 16, 2005 | 10:29 AM
dubcac's Avatar
dubcac
I
I didn't have to remove anything but the old header...just takes some maneuvering.
Old Jul 16, 2005 | 12:00 PM
qtiger's Avatar
qtiger
Old Jul 16, 2005 | 12:13 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I had to pull the slave cylinder off in order to get it in.
It was a pain in the ass for what it was worth, but I got it in. It may help to remove the AC condensor fan to give yourself some more room.
Old Jul 16, 2005 | 01:45 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
There is no way you can get that thing in from the top. :rofl:
Just takes some maneuvering, as earlier stated.
Old Jul 16, 2005 | 04:41 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
On my 99 it was no problem for me. I removed the heat shield. Sprayed all the bolts up top, got under the car, undid it from the cat, a twist and a turn and it drops right down. Put the new header in, bolted it to the head, zip stripped the tension springs closed, got back underneath, made sure my donut gasket was installed and badda bing, badda boom, Joey Buttfuoco.
Old Jul 16, 2005 | 06:10 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
i did mine from under...i also took my ac and radiator fan off for some extra room.
Old Jul 18, 2005 | 08:23 AM
newgsrdriver's Avatar
newgsrdriver
Yep, just manuever it up from under the car. You shouldnt have to remove your rad or fans.
Old Jul 18, 2005 | 08:43 AM
bnuk's Avatar
bnuk
ditto. I put my DC in from the bottom with my car only 1 foot and half off the ground on jack stands. You have to kinda hold it sideways to get it started. Once you get it right it should go right up with out any scraping or or anything. keep in mind though that it was close so a different header w/ different shaped runners might not fit.
