JDM ITR Hub, Brake help
Hi everyone,
I have been searching everywhere and cannot find the parts or specifications for the rear brakes and hubs. Hopefully one of you can point me in the right direction.
Bought and installed JDM ITR rear disk set up. In my stupidity, didn'y realize the lugs where 4 x 114.3. The suspension has been powder coated and has Prothane bushings. It was suggested to buy some GSR hubs and install. I did and they do not work.
This is what I know:
Spindle diameter is the same.
Hub height is the same as GSR.
Hub pilot diameter is the same.
Differences:
Bearing length is shorter on the GSR by approx 10mm.
Hub I.D. is machined to a larger diameter. The hub acts as the outer race.
So, the bearing package is slightly larger. I could machine a spacer and place it on the spindle outside the bearing and lock it in place. This would work but would rather utilize the larger bearings if possible.
Does anyone know what part will give me the 4 x 100 with the larger bearings?
Also what size rotor will be needed? They where in poor condition and discarded.
Differences:
That is a very good consideration and we talked about it. It is a project car with my son and I. We have bought the SSR competions and they are not available in the 4 x 114.3. Purchased through Tire Rack.
