Argh...Battery issue
Old Jul 14, 2005 | 07:01 AM
Oldschool's Avatar
Oldschool
Boondock Saint
Default Argh...Battery issue
As some of you may know, I am running an optima yellow top battery. After sitting for a long period of time (say, 4+ hours) it fails to start. It's been exhibiting this behavior for the last 2 days. At first, I thought it was the alternator, but When I disconnected the battery the car continued to run.
That leads me to believe it's the battery.
Also, I am running 2 amps + a head unit, vtec controller and my fuel/air & Volt gauges.
Doesn't seem like too much load....
Guess's, thoughts?
Thanks In Advance
Old Jul 14, 2005 | 07:32 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
Optimas can take way more of a beating than that..
My dad's escalade can run with his 1000w amp and subs going without the engine running for 45min flat before being drained one of the dual-yellowtops he runs...
Wasn't it you saying that you had your battery routed into your trunk?
I'm willing to bet there's something wrong between point a and point b.
Old Jul 14, 2005 | 07:48 AM
Oldschool's Avatar
Oldschool
Boondock Saint
Yup, battery is in the spare tire well. I have had the battery in the trunk for almost 8 months. This issue is only two day old...
Old Jul 14, 2005 | 08:22 AM
Oldschool's Avatar
Oldschool
Boondock Saint
Me thinks I figured it out...I think I am running more amps than the alternator can supply. I am not running capacitors, and my volt meter drops when the bass kicks...anyone know of a higher output alternator that will work for my teg? Stock is 90...
Old Jul 14, 2005 | 09:10 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
That shouldn't cause start failure... especially with a decent battery.
Make sure the amp itself is turning off when you turn the car off?
That happened to my dad's amp, it wasn't shutting off, so it was draining the battery.
Old Jul 14, 2005 | 09:16 AM
Oldschool's Avatar
Oldschool
Boondock Saint
Well, i also noticed that it has been about 2 weeks since I put my system in. My alternator only supplies 90, I am running (if I did the math right) 105. If the alternator can't keep up than the battery get more and more drained because the alt is not recharging the battery as quilky as I am depleting it with my subs....
I also checked the amps...all the lights are off...it sure looks powered off.
Old Jul 14, 2005 | 10:10 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
grab a cap I guess then? You'd have better luck/answers in the Audio & Security thread...
