trunk light
Old Jul 5, 2005 | 12:17 AM
dipstick86's Avatar
dipstick86
Default trunk light
I have a G2, and the light in the right wall of the trunk is busted. The bulb is good, so I figure it's something wrong with the switch. Question is, where the hell is it? the switch I refer to is whatever turns it on when the hatch is opened. I'd love to be able to see what's in my trunk without hauling a flashlight around.
Old Jul 5, 2005 | 03:01 AM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
not sure on 2g integra, but on my accord an evo, it's on the latch itself. check for a wire going to the latch, and use a screwdriver to test the latch(closed while the trunk is open).i would double check the bulb as well cause sometimes they look good when they blow.
Old Jul 5, 2005 | 05:17 PM
dipstick86's Avatar
dipstick86
I've checked the bulb, it's good. I've fiddled around with the latch without actually taking anything apart and I can't see anything, no wires in sight. I'll unscrew whatever unscrews tomorrow in search for it, any idea what sort of switch I should be looking for?
Old Jul 5, 2005 | 09:49 PM
Phateless's Avatar
Phateless
S2K compatible
i guess my 95 gsr DOES have a trunk light...i was not aware of that. i'll go search for mine too then...
Old Jul 6, 2005 | 04:30 PM
dipstick86's Avatar
dipstick86
Bump...
if the switch is in the latch, how do you open that stuff up to poke around?
Old Jul 6, 2005 | 05:24 PM
Lsvtec503's Avatar
Lsvtec503
My trunk light wasn't working in my gsr when I first got the car. While removing my antenna motor I found out that the wiring harness had got unplugged from the back of the light assembly.
