my taillights
Old Jun 25, 2005 | 08:30 AM
TheKillaColonel's Avatar
TheKillaColonel
Default my taillights
ok guys
i just got some new taillights for my 94 ls teg. they look great but they don't have any wires or bulbs in them. I hope this is standard. also how do i go about removing my old ones? do i have to take that plastic off the back of the trunk or what?
Old Jun 25, 2005 | 09:42 AM
VTEC-Power's Avatar
VTEC-Power
yes...
Old Jun 25, 2005 | 09:48 AM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
...Wow....Thats....Nevermind I can't say it...
There are little nuts holding the lights in. Look for the positions on your new ones. And no, the harness does not come with the lights, they're on your car...
Old Jun 25, 2005 | 12:31 PM
Integral's Avatar
Integral
Nightmare Motorsports
I just bought new lights too... and you have to remove the two side panels on the left and right side of the trunk, they are opposite the taillight position. These pop right out... then there are 3-4 screws on each side that you must remove... and then you unplug the wiring harness from the old lights and remove them... once they are out you must take the actual 4 wire harness where bulbs connect. You don't even need to remove the bulbs from their casing in the wiring... just take the whole small wire assembly out. If your new lights are anything like mine then there isnt an actual place in the new lights to hold the harness securely, so I had to just position them and then close the plastic pieces after I installed the tails... I'd also recommend that you test the lights and their appearance before you close everything back up and screw them in. Hope this helps ;p
Old Jun 25, 2005 | 02:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would pick up a new taillight gasket before you do the install to eliminate any chances of water leaking into the trunk and lights.
Please tell me you didn't get altezzas....
Old Jun 25, 2005 | 02:49 PM
TheKillaColonel
lights look great ill post a pic later.
thanks
guys
also there is a slight crack inbetween the top the of the light and the car, should i be concerened about water getting in?
Old Jun 25, 2005 | 03:16 PM
Provocateur
On permanent hiatus
A slight crack below the body and top of light is normal.
As long as the gasket is in good condition or new, you shouldn't have a problem with water leaks.
Old Jun 25, 2005 | 04:00 PM
carta79's Avatar
carta79
Life after death
altezzas?????????????
Old Jun 25, 2005 | 08:27 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
do you guys really need to ask if there altezza's?? Come on now, we know the answer to that question....
Altezza's they are :nono:
Old Jun 25, 2005 | 09:53 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Man. I saw a Dodge Grand Caravan with altezzas today...I wanted to go buy a gun and shoot the middle aged woman... I have altezzas on my teg, I like the look better on tegs than on most cars.
