RPM chip
Old Jun 9, 2005 | 12:20 PM
19Integra92's Avatar
19Integra92
Default RPM chip
i'm thinking of buying a 8500 rpm cheap for my ls.. but i dun want to take the risk of blowning my value n piston... what u guys think?
Old Jun 9, 2005 | 12:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Taking an unreinforced LS block to that will blow your motor. Unless you plan to reinforce it, don't do it. The stock rev limits are there for a reason.
Old Jun 9, 2005 | 02:58 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i wouldnt buy those things, they royally fawk up your motor and your bone stock motor wont be able to handle it like shmoo said.
Old Jun 9, 2005 | 08:38 PM
HondaAkudou's Avatar
HondaAkudou
i agree wit them too.. maybe if u build ur engine up.. n put vtec head in there.. the chip would proably work but no guarantee.. cause that seem alot of torque for juss LS
Old Jun 9, 2005 | 08:46 PM
Provocateur
On permanent hiatus
You can still put a vtec head and blow the motor to shit. Yes, it will make power that high, but the stock LS rod bolts and bottom end were not designed to rev that high. You need to reinforce it with at least stronger rod bolts, a balanced bottom end, and possibly a main girdle.
shabacash's Avatar
shabacash
I'M SO JDM, I HAVE SARS
agree with all of the above
Old Jun 10, 2005 | 04:15 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
yeah i also agree, i wouldn't do any of that to my car
Old Jun 10, 2005 | 12:12 PM
GSR4444's Avatar
GSR4444
there would be no point in having that chip. Unless you have other camshafts/valvetrain, you wont make anymore power. If you notice any dyno sheet, the power drops off as you near the redline, so unless you have other modifications, you wouldn't gain anything.
Old Jun 10, 2005 | 02:55 PM
9600baud's Avatar
9600baud
JDM rox ur world
well if all you're worried about it "blowning a value n piston" i say the chances of that happening (whatever that means) is zero.
Old Jun 10, 2005 | 03:00 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
all you'll be making is more noise in an RPM range that high with a stock LS
Save it for when you build a motor. I would never use generic chipping anyway. Adjust your rev limiter with an EMS or something reliable and known.
