why does my gas mileage = teh suck?
Old Jun 5, 2005 | 06:34 AM
reno96teg's Avatar
replace your thermostat asap. your engine is not running at optimal temp., so yes, that will affect gas mileage. it doesn't hurt to replace the cap and rotor either. if they're sufficiently worn, your spark will likely not be as strong, leading to less than ideal combustion.
bad o2 sensor can affect things as well. see about getting that fixed.
Old Jun 5, 2005 | 07:00 AM
ED9man's Avatar
ED9man
driver
How is the ECU reset?
Old Jun 5, 2005 | 07:16 AM
carta79's Avatar
carta79
Life after death
For a CRX or 3rd Gen Integra.
For 98+ Integras
-Turn the ignition switch off. Remove the BACK UP (RADIO)(7.5A) fuse from the under-hood fuse/relay box for 10 seconds. Be sure to have the code for the radio if you still have the factory unit.
Team Integra ECU reset article
Old Jun 5, 2005 | 10:11 PM
VTEC-Power's Avatar
VTEC-Power
your cat can be bad
Old Jun 5, 2005 | 10:12 PM
VTEC-Power's Avatar
VTEC-Power
also maybe a better airfilter will help
Old Jun 6, 2005 | 03:28 AM
R_Squared's Avatar
R_Squared
LEVEL UP
If my cat were bad, wouldn't I be able to tell? I thought it was supposed to smell like sulfur when your cat goes out or something...Also, my Intake Air Temp Sensor has been broken off ever since I bought the car. Could this be a big contributing factor too?
Old Jun 6, 2005 | 08:23 AM
VTEC-Power's Avatar
VTEC-Power
well it could be clogged
Old Jun 6, 2005 | 09:14 AM
carta79's Avatar
carta79
Life after death
There are check engine light codes for both the cataytic converter and intake air temperature sensor. If there was something wrong with either of them I would hope that the ECU would figure that out and throw a CEL.
Old Jun 6, 2005 | 10:51 AM
VTEC-Power's Avatar
VTEC-Power
i dont think it would if it was clogged, get a pen and tap the cat and see what you hear
Old Jun 6, 2005 | 07:13 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Right now, I'm just throwing codes for my O2 sensor and IAT sensor...
