question about shocks
Old Aug 30, 2002 | 08:43 PM
el diablo's Avatar
el diablo
Jeeebus......Help Me!!!!!
Default question about shocks
There is a threaded bolt like thing on the top of the shocks that has a nut on it and can be turned to adjust the bolt like part up or down. My question is what is the purpose of this bolt and what is a recommended hight or thread count sticking out of the shock? I hope someone understands what i mean. Thanks in advance, Luc
Old Sep 5, 2002 | 01:40 AM
el diablo's Avatar
el diablo
Come on now, Somebody has to have an idea as to what Im talking about???
Old Sep 5, 2002 | 03:09 AM
snowman's Avatar
snowman
Stock shocks?
Old Sep 5, 2002 | 04:18 AM
el diablo's Avatar
el diablo
Well I got kyb agx shocks now but the it was the same on the stock shocks.
Old Sep 6, 2002 | 04:54 AM
snowman's Avatar
snowman
Since no one here (including me) seems to know, why not call a KYB distributor and ask them?
Ferd
Old Sep 6, 2002 | 12:38 PM
Taiwanze7's Avatar
Taiwanze7
you mean:
the two bolts just help hold the shock together the top part which is yellow and sticks out is where the koni yellows adjust....as I recall, the KYB AGX knob is somewhere lower on the shock
Old Sep 6, 2002 | 01:39 PM
el diablo's Avatar
el diablo
yes the middle where the konis adjust. On the kybs they adjust in the same spot but with a screw driver. I will take a picture later maybe that will help out. thanks
Old Sep 6, 2002 | 02:12 PM
stumpyf4's Avatar
stumpyf4
No spec on the height of the threaded portion just the torque on the bolt. Something like 35ft/lbs but don't quote me. Problem is that the shaft turns as you tighten it so you have to keep the shaft stationary as you torque the nut...using a regular socket on the torque wrench it can't be done. Probably some special socket that has a cut-out in it that allows you to use a wrench or allen key to hold the shaft stationary.
The purpose of this bolt is to keep the shock/spring assembly together.
CivicSiRacer
92+ Civic/EL & Del Sol
2
Dec 2, 2009 05:39 AM
honda_609
2
Nov 3, 2007 08:47 PM
ye1lowxb0i
Jan 28, 2004 08:08 PM
Accord 4U2 NV
Accord
10
Sep 3, 2003 03:01 PM
