b&m fuel pressure gauge help..
Old May 29, 2005 | 01:35 PM
danteisme's Avatar
danteisme
Default b&m fuel pressure gauge help..
i just installed my b&m fpr and gauge...the install went fine until it came time for the gauge. its leakin gas, and i uninstalled and reinstalled it about 7 times to see if it was just a mistake i made. i applied telfon tape to all the areas it said to as well as on the brass fittin to the fuel filter. still leaking! its leakin between the brass fittin/copper washer and the banjo fuel line. i cant figure it out, all the washers are in good condition and are not bent at all. i cant understand why its still leakin, any helpful ideas?
Old May 29, 2005 | 02:33 PM
dubcac's Avatar
dubcac
I
Try redoing the teflon tape and do it again...make sure it's tight enough.
Old May 29, 2005 | 04:45 PM
danteisme's Avatar
danteisme
im gonna try it again tomorrow, someone told me to use fuel safe teflon tape, im not sure if this kind i used is, so i will start there
Old May 29, 2005 | 04:47 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Did you use new crush washers? If not, that's likely your problem.
Old May 29, 2005 | 05:13 PM
danteisme's Avatar
danteisme
i used the washer that came with it and it said to use the stock on on the bottom of the banjo line if it is in good shape. it looked nice and straight, not warped so i reused it, i think i may replace the tape and both crush washers tomorrow if i can find someone open tomorrow that will have them.
Old May 30, 2005 | 08:39 PM
qtiger's Avatar
qtiger
Bleh, I'm not too impressed with B&M. My gauge is stuck at 42.5 PSI. Unhooked the fuel rail the other day, needle didn't budge. :doh:
Old May 30, 2005 | 09:52 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What would you recommend instead? I need a FPR and gauge before I book dyno time and I am stuck on which one to get.
Old May 31, 2005 | 01:09 PM
qtiger's Avatar
qtiger
Just keep an eye on it and if it goes sketchy get something nicer, and you'll already have the mounting hardware.
Old May 31, 2005 | 01:21 PM
dubcac's Avatar
dubcac
I
I've heard a lot of people having problems with the AEM FPR as well. I haven't heard so many problems about the B&M FPR, but the gauge.
Old May 31, 2005 | 01:35 PM
qtiger's Avatar
qtiger
Yeah I can't comment on the FPR, I'm just using their gauge.
