need engine help bad
Old May 28, 2005 | 02:18 PM
2tone's Avatar
2tone
CJ
Default need engine help bad
Okay i have a built 2001 gs it has:
Cold air intake
crower cams stage 1
aem cam gears
header
je pistons 10.5 to 1
bored out .30 over stock
jet performance computer
Stock valves and valve springs
stock rods and crank
I am wondering if the higher compression will cause major valve chatter around 20 to 40 mph or could the computer that Jet programmed be advancing the timing causing the chatter.. Do i need vavle spring and retainers? I need help
thanks
Old May 28, 2005 | 03:15 PM
ED9man's Avatar
ED9man
driver
Get rid of the computer if it is just some cheap non-programable/non-tuned thing, just run the OEM ECU or get an APEX-i SAFC. Adjust your valves.
Old May 28, 2005 | 09:38 PM
Snoopy's Avatar
Snoopy
been there done that
definitely get something programmable. if you're valves are making that kind of noise they need to be adjusted. you will only need the springs/retainers if you plan to take it above the stock rev limit. which i recommend you do not.
Old May 28, 2005 | 11:19 PM
Kai's Avatar
Kai
Rotorphile.
Valve chatter is purely mechanical. If you're keeping it at the stock redline, you have a serious problem. Adjust the valves and troubleshoot after that.
