Car Won't Start
Old May 14, 2005 | 10:30 AM
tomzxtt's Avatar
tomzxtt
Default Car Won't Start
I have an 89 integra. It will not run. I pulled a wire and put a plug in it and tried starting the car and the plug sparked so i know im getting spark. i also pulled the return fuel line off and tried starting the car and fuel started pumpin out when i did, so i know im getting fuel atleast to the injectors.
So i'm getting spark and im getting fuel to atleast the injectors but the car will not run. I checked the EFI fuse and it is fine. i never had any problems or signs the car was not working right, it just would not start one day.
What can i do/check/fix next???
Please help me!
Old May 14, 2005 | 10:42 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Does the engine catch a little bit, or does it just turn over?
Old May 14, 2005 | 02:13 PM
Carfan1's Avatar
Carfan1
Timing belt is ok?
Old May 15, 2005 | 08:01 AM
tomzxtt's Avatar
tomzxtt
the car doesnt seem to catch at all and the timing belt was changed less than 10k ago and i moved the cover to peak at it and its still on there
Old May 16, 2005 | 07:29 PM
BlaqueGhost's Avatar
BlaqueGhost
i had a similar problem on my 90
the timing belt jumped, engine just kept turning over but wouldnt start
Old May 17, 2005 | 06:19 AM
okiedokie's Avatar
okiedokie
Sounds like a problem I just had. My distributor went out and took my main relay switch with it. Had to replace both.
