What can it be?
Old May 13, 2005 | 09:17 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
Default What can it be?
sorry for posting this so many times. I just need a answer or solution. I dont have power going to my compressor and my cond. fan.
my relays are good in the under hood fuse box. anything else that would be killing power going to the comp. and my cond. fan.?
Both of them are working fine. Just no power to them.
Old May 14, 2005 | 01:07 AM
shabacash's Avatar
shabacash
I'M SO JDM, I HAVE SARS
[liljohn] WHHHHAAT? [/liljohn]
Old May 14, 2005 | 01:23 AM
Takumi Fujiwara's Avatar
Takumi Fujiwara
Have you tried turning the A/C on, then running a volt meter on the condensor fan wires to see if there is actually power going to them?
I'm sure you've checked all your fuses already...
You should also check the wires that connect to the plugs of the fans... make sure power is actually going through them.
Old May 14, 2005 | 10:38 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
lol. every time i tested the ac was on. the rad. fan has power and runs fine. the ac fan doesnt. i hotwired the fan and it works. i also hotwired the compressor and it works. i need to find out what the prob. is in the electrical system. any suggestions?
Old May 15, 2005 | 04:17 AM
Carfan1's Avatar
Carfan1
Get a wiring diagram and check for power at the switch and at every component after the switch. If you need a wiring diagram I can get one.
