Any Ideas on Stroker Kits?
Old May 13, 2005 | 09:33 PM
Snoopy's Avatar
Snoopy
been there done that
www.goldeneaglemfg.com
www.erlperfomance.com
benson's
Old May 14, 2005 | 10:46 PM
TegManGS-R's Avatar
TegManGS-R
Blake Brown
thanks snoopy. i think i am going to go with bensons. if i get it resleeved will i be able to rack up the rpms in the block? i know i need internals. but will the block take it?
Old May 15, 2005 | 08:21 AM
Snoopy's Avatar
Snoopy
only rev it as high as it will make power to. upgraded internals, balance the rotating assembly, and it will handle high rpm's.
Old May 15, 2005 | 08:32 AM
dubcac's Avatar
dubcac
I
If you have cams that can make power to 10k rpm and valvesprings/retainers to match, you can rev it that high with a good set of rods, and a balanced/weight matched rotating assembly...rods/pistons weight matched, balanced rotating assembly. The engine's gotta breathe, so you'll probably want an aftermarket intake manifold, and a port and polish job on the head.
