Fuel Problems?
Old May 8, 2005 | 03:38 PM
snobrdrskatr's Avatar
snobrdrskatr
Default Fuel Problems?
does anybody know if installing a walbro 255 fuel pump will mess up the pressure to the injectors and cause it to not start?
it has been having a lot of problems lately and only starts when i use starter fluid into the intake manifold. it seems to have decent spark...its white...and i just replaced the battery but i have no idea what it could be other than the fuel pressure regulator? Tell me what you think.......
thanks
Old May 8, 2005 | 06:29 PM
Carfan1's Avatar
Carfan1
If it starts on starting fluid does it stay running?? If not then you have a fuel supply problem, does the pump work? If it stays running after you get it started you have a volume or pressure problem.
Old May 8, 2005 | 09:35 PM
snobrdrskatr
yeah it stays started most of the time...sometimes if i put starter fluid in it then i go start it and give it gas and let off when it starts and it revs and then dies when i let off the gas...
Old May 9, 2005 | 06:11 AM
Carfan1's Avatar
Carfan1
Sounds more like a vacuum leak than a fuel problem. Try leaving your intake snorkel assy together and cranking the car while spraying starting fluid at potential vacuum leak sources. See if the car will start that way. I had this prob on my beater escort. We thought the intake gasket was leaking, but the fluid was hitting the intake and being sucked in through the egr gasket. This really sounds like an air problem, not fuel.
