Bad engine... need advice...
Old May 3, 2005 | 10:45 AM
Bui1t2Spill's Avatar
Bui1t2Spill
Default Bad engine... need advice...
Well i just heard from the mechanic that my engine is pretty much shot... has some major cracks in it. So im gonna have to get another engine. Ive been looking on www.osakajdmmotors.com and they have some type R's for 3950-4200$ (depending on year) Just wondering how those prices sound to you guys. Also since i have the choice.. instead of the type R engine would you guys recommend me replacing it with something else. Since ive driven my Type R so much i dunno if i can put anything else in there and be happy with it. But im open for suggestions. Anyways thanks for any input.
Old May 3, 2005 | 12:38 PM
Dave-ROR's Avatar
Dave-ROR
RAD owns.
Those prices are normal. You may want to use a different motor depending on your goals. What do you use the car for and what do you want out of it?
Old May 3, 2005 | 02:20 PM
Bui1t2Spill
well i do drive quite a bit for work so i put alot of miles on my car. i was very happy with what i had in there before it blew. I hadn't planned on doing any other engine work or anything as far as performance goes. Are those engines not very good for reliability?
Old May 3, 2005 | 02:22 PM
Dave-ROR's Avatar
Dave-ROR
RAD owns.
No, they are fine. Well I've never dealt with Osaka but I'm sure you can find info on their motors, but in general the B18C Spec-R/B18C5/etc is a fine motor reliability wise. I just meant that if you want a motor with 230whp you might want to look into different options.
Old May 3, 2005 | 02:24 PM
Bui1t2Spill
oh ok i see what you mean. But ya i was just content with what i had. The engine that was in there was a US version of the R it wasnt the JDM spec. Are they about the same performance wise?
Old May 3, 2005 | 02:29 PM
Dave-ROR's Avatar
Dave-ROR
RAD owns.
There are some differences, it's easiest to buy a USDM motor, JDM isn't a hard swap but a little more involved. On the plus side you'll get higher compression..
Old May 3, 2005 | 02:35 PM
Bui1t2Spill
seems like www.osakajdmmotors.com has the best prices ive found on the net. As far as more involved do you just mean with like the wiring or are the mounts and stuff not going to be the same?
Old May 3, 2005 | 02:37 PM
Bui1t2Spill
http://www.osakajdmmotors.com/codes/hondaB18CR2.htm thats the one im looking at.
Old May 3, 2005 | 02:46 PM
Bui1t2Spill
actually ive been reading about osaka and ive been hearing alot of bad reviews... alot of good ones on www.hmotorsonline.com
Old May 3, 2005 | 03:08 PM
Snoopy's Avatar
Snoopy
been there done that
do you have to replace the entire engine? if not, i would just look into getting another block and rebuilding that or doing the same for the head.
