Need help picking a turbo for 96 GSR
Old May 2, 2005 | 10:58 AM
The Baller's Avatar
The Baller
Default Need help picking a turbo for 96 GSR
I have a 96 GSR and am looking to add a turbo to my setup. My question is will I have to get a turbo kit for a type r because I have a skunk 2 intake manifold? Also does anybody know of any sites that have cheap prices for new or used turbo kits? Thanks. Current setup: Stage 2 clutch, Skunk 2 Intake Manifold, AEM SRI, Magnaflow Exhaust.
Old May 4, 2005 | 07:15 AM
hawaii_boy71's Avatar
hawaii_boy71
there is no cheap turbo kits
Old May 4, 2005 | 08:17 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
What state are you in, and what are your goals?
You cannot use a kit designed for an ITR because the exhaust manifold bolts up differently. You would need a kit designed for a GS-R, but with some custom piping to make it so the Skunk2 manifold fits.
There are no cheap turbo kits. There are junkyard turbo setups you can assemble for cheap, but that's a ghetto solution.
But before we get there, what are your goals?
Old May 4, 2005 | 01:05 PM
Ziken's Avatar
Ziken
RACE USE ONLY
when he means cheap, i think he means the cheapest turbo kit he can get
Old May 4, 2005 | 03:38 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Cheapest you can get would be build your own, I'm educatededed guessing.
Old May 4, 2005 | 03:48 PM
greengsr2k's Avatar
greengsr2k
BRO JUST GET A LS KIT. THE EXHAUST MANIFOLD WILL BOLT ON. I BOUGHT A GREDDY TURBO KIT LS KIT FOR MY 00 GSR WITH SKUNK 2 INTAKE MANIFOLD. I DID RESEARCH AND THE LS KITS ARE THE BEST KITS TO MAKE IT WORK FOR THE GSR WITH SKUNK 2 INTAKE MANIFOLD. PLEASE VERIFY IM CORRECT GUYS. THE ONLY THING THAT MIGHT NEED MODIFICATIONS IS THE CHARGE PIPE, I BELIEVE NEED TO BE EXTENDED.
Old May 4, 2005 | 03:56 PM
Epoch's Avatar
Epoch
3 things:
1) No caps
2) What research did you do? GReddy kits are anemic, and should only be bought if you want a easy install that's CA legal. There's a half dozen faster and cheaper kits out there that are better in every respect except for CARB exemption.
3) Why the hell are you reccomending a bolt on kit for a car he doesn't have? What justification do you have for suggesting he eliminate the only benefit of a GReddy kit by putting it onto a car that will make it's CARB legality null and void?
Old May 4, 2005 | 06:27 PM
greengsr2k's Avatar
greengsr2k
back off epoch
Old May 4, 2005 | 10:03 PM
PHiZ's Avatar
PHiZ
BOOST GOD
B-Series exhaust sides are the same. Intake manifold bolt pattern is different...
-PHiZ
Old May 4, 2005 | 10:48 PM
Chizzy's Avatar
Chizzy
what's CARB legality? can you get decent turbo kits that are not illegal in canada due to smog restrictions...specifically Vancouver, BC
