Driver door lock broken, help
Old Apr 29, 2005 | 03:40 PM
Chizzy's Avatar
Chizzy
Default Driver door lock broken, help
On my 94 RS the door lock will not stay in the open position. To get in I have to insert the key turn the key and *hold* the lock in the open position and pull the latch simultainiously. Same thing from the inside. Should I remove the door panel?
Old May 1, 2005 | 08:35 PM
Chizzy's Avatar
Chizzy
I went in there 2day, sprayed some WD-40 all over the lock mechanism and after about an hour of moving it around I was able to get it to move freely all the time except when the door is open(which you don't need anyways)..very weird.
