Auto LS Integra turbo it? or not?
Old Apr 27, 2005 | 08:07 PM
unholylight's Avatar
unholylight
Default Auto LS Integra turbo it? or not?
LS B18B1 1834 Displacement, 9.2 : 1 compression ratio (CC's) , 142 HP @
6300 rpm 127Torque lb/ft @ 5200 rpm USA made
Hi, im thinking about turboing my integ (LS 4dr automatic) but im not shur if i should, i heard that it might hurt my tranny and if i do im not shur about all tha parts that i might need. If u have n e info it would b helpful. (btw would i need a psi controler to control how much psi goes in? what would/ should b tha limit? ) no BS plz, onli experienced words that will help with my decision please.
Thank you
Old Apr 27, 2005 | 08:41 PM
jr_kbad's Avatar
jr_kbad
get ready for answer such as:
"sell your car and buy a manual"
"autos suck"
"no point"
"search the forums"
Hope you get what you are looking for.
Old Apr 28, 2005 | 05:39 AM
VTteg's Avatar
VTteg
From what I hear, the automatic transmision just cant handle the extra HP that a turbo deliver. If you still want more power I would suggest cams, breather mods, and then a fresh tune on a dyno or with Hondata or Uberdata.
Old Apr 28, 2005 | 08:31 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
As I have said before, the auto trans soaks up so much power, nothing short of a turbocharger or supercharger will make a meaningful difference in performance.
At the same time, however, the automatic transmissions are quite fragile. When you start adding another 50 hp or more, a lot more heat is generated internal to the transmission and it's that heat that leads to internal failures.
So if you want a fast automatic Integra, budget an additional $1000 to have a transmission shop (like Area 51, if they're still in biz) to completely overhaul and upgrade the transmission internals.
Old Apr 28, 2005 | 08:33 AM
TheOtherDave™
Apathy Kills
And that $1000 dollars is on top of the costs for actually turbocharging the motor.
So at an absolute minimum, you're looking at $3500 in motor and trans.
Old Apr 28, 2005 | 09:20 AM
StreetShark's Avatar
StreetShark
Yeap I fill your pain I'v herd it before when my ls use to be a AT
Old Apr 28, 2005 | 03:58 PM
unholylight
hm, then how much would it b to change my car to a stick?
Old Apr 28, 2005 | 04:02 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by unholylight
shur
sure.
tha
the.
u
you.
n e
any.
psi controler
boost controller.
onli
only.
You spell like you grew up in DC. People are much more willing to help when they don't have to spend five minutes making sense out of what you type.
Sell it and buy a manual..
An auto should survive indefinately with a super-light wastegate spring and a boost controller set around five pounds.
Old Apr 28, 2005 | 04:44 PM
EviLLLLSiNz's Avatar
EviLLLLSiNz
n00b
teg auto trannys are notorious for breaking. my friend replaced his just under 110k miles i think >.<
turboing it wouldnt help
Old Apr 28, 2005 | 04:54 PM
Snoopy's Avatar
Snoopy
been there done that
sorry to be the bringer of bad news...but your integra was made in japan :reechy:
